AutoCAD Forum
Multileaders - Delay when selecting
3 REPLIES 3
rsBria
624 Views, 3 Replies
The problem at hand is:
Attempt to select a multileader (any multileader in my drawing) and I get the spinning wheel of wait for at least 20 or 30 seconds-which is an eternity.
I should note, this was not happening in my drawing until I copied in a polyline from a coworkers drawing.
3 REPLIES 3
jggerth
in reply to: rsBria
did unexpected linetypes or text styles suddenly show up also?  if so possibly you've been infested with DGN Bloat?
rsBria
in reply to: jggerth
Yes, That's exactly what happened.  I took corrective measures by downloading the autodesk hotfix: AutoCAD_2013_2014_DGN_Hotfix.zip
I followed the readme instructions for this solution and was able to purge 900+ dgn linetypes, but I still have the delay problem when selecting any multileader. I have ran dgnpurge, purge, audit several times.
Thanks for your quick response by the way.
rsBria
in reply to: rsBria
Problem solved. I just realized I was so focused on it being a linetype problem I didn't purge out the text styles....duh.
”Boost
