Hi I have block, circle with attribute and used it with multileader and it looked nice. But after I closed the drawings and reopened them the day after the center of the multileader goes in to the middle of the circle. If I open the mleaderstyle click modify and ok then it's ok except then it jumps a little to the side and my dot disappears of the ones that are to near so I have to go over everything and stretch it back.
Pleas help me I was so happy to have ballon for my items and used it everywhere and now it's a mess.
The circle is a block with attribute so I think I can't use any landing options except attachments that I use insertion point.
Thanks but there lies my problem. In my template I made multileader where the attachment is insertion point then I use them, everything looks great I printed it out, save and close. The day after I open my drawing and want to keep working with it and actually it was 15 drawings they had all changed the block to center extents (and if you do it manually it dosen't go into the center but to the side of the circle).
And here comes the second problem to fix it I just have to open the mleaderstyle and modify and ok without changing anything because it says insertion point like its suppose too and then it pops back but it also jumps a little bit to the side so it's not like I want it to be. So I have too stretch it back.
Any other ideas ?
I had the same problem and found this tread. I just noticed my UCS was to obj. I changed back to WCS and all works great. Check your UCS and let me know.
I am having the same problem. With a Dview twist set to 90° and then my UCS set to View, when I create an mleader with a bubble block that I created, the leader tail is inside the bubble when it's left justified but the leader tail is outside the bubble like it should be when it's right justified. However, the default _tagcircle block that comes with cad, it works find both directions. My custom bubble is the one with the white background in it.
Following this thread for sure. This has happened to me in various drawings in civil3D for years. I'm not sure what causes some drawings to go bad in this way.
There has been times that moving items in the block off the 0-layer has fixed the problem, but not always.
