AutoCAD 2013/2014/2015
Product Support
luconceicao
Message 11 of 18 (425 Views)
Re: Multileader not extending to text
04-27-2012 07:13 AM in reply to: Vandeurzen
Our developers were able to reproduce the issue and they are working on the matter.
This does not seem to be OS related, so not a Vista conflict.
Cheers,
Luciane
Active Member
Vandeurzen
Message 12 of 18 (421 Views)
04-27-2012 07:45 AM in reply to: mt1083
I am running Windows XP SP3.
Active Contributor
mt1083
Message 13 of 18 (420 Views)
04-27-2012 07:51 AM in reply to: luconceicao
Yeah I figured it was probably not related. Thanks for starting the work on the fix though!
Distinguished Contributor
damo3
Message 14 of 18 (393 Views)
05-22-2012 06:43 PM in reply to: luconceicao
Having IDENTICAL problem here with multileaders as to what has been explained in this post. Has anyone also noticed when selecting a grip on the text box (eg: the bottom left grip), it no longer aligns the cursor with the very front of the text box? There is a slight indent now of the cursor once the grip is selected.
While we are working through fixes, have there been any reported problems with the Moroco tool? Had 3 fatal errors using this tool. Problem is intimitent though. I have sent reports to Autodesk.
New Member
dallasghagler
Message 15 of 18 (358 Views)
06-27-2012 06:08 AM in reply to: mt1083
I am having the same problem. We just switched to AutoCAD 2013 from 2012.
Windows 7 Operating System
Active Member
arq002
Message 16 of 18 (309 Views)
09-14-2012 04:40 AM in reply to: Vandeurzen
Has a patch for this been available yet? I have the same problem, just a little different.
See attached.
Product Support
luconceicao
Message 17 of 18 (272 Views)
10-04-2012 07:36 AM in reply to: arq002
Have you already installed the service pack 1.1?
AutoCAD 2013 SP 1.1: http://usa.autodesk.com/getdoc/id=DL20327837
Cheers,
Luciane
Active Contributor
mt1083
Message 18 of 18 (266 Views)
10-04-2012 08:00 AM in reply to: luconceicao
I just installed the service pack and that seems to have fixed the issue. Thanks!
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
