Does anyone else have this problem or know away around it?
When I enter the text for an MLeader, if the first word, for example "NOTE" is followed by a colon with more words following when you hit return for the next line an incremented prefix added.
see attached
Kim
Solved by GrantsPirate. Go to Solution.
While in the mtext portion of the mleader placement, right click, pick bullets and lists and turn that off. Also you can do that from the ribbon while in mtext.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Thanks, that did it.
Kim
