I'm trying to find a way to be able to manually re-size a ML landing without the Text/Block moving (why it moves at all baffles the mind).
Can anyone offer a solution?
I know you can align them afterward using "mleaderalign", but I'm looking for a solution that doesn't depend on trial/error (with the current method it's possible you may have to do this more than once to get the right layout).
Solved by doben. Go to Solution.
You can do this with QL.
If you move the cursor over the landing grip you will get a shortcut menu and can then adjust the distance (Lengthen Landing) without affecting the text position. Please see attached.
Nice. I got to learn something new. Thanks (though i think it would be more intuitive if they had put the arrow on that end instead..)
