When I edit or create MTEXT the text editing window is HUGE. Attached is a screen shot of how the text looks in the drawing and also how it looks after I click on it to edit it. Similar behavior happens when the text is originally created.
How do I keep it from enlarging the text so much when it's created or edited? I'd prefer to have it stay the size as it is displayed on the screen before I click on it to edit.
Autocad 2015.
Solved by nrz13. Go to Solution.
Double-click on the MTEXT to open the editor. Either right-click in the text box or on the pull-down arrow on the top right of the editor toolbar, select "Editor Settings" → "Always Display as WYSIWYG". That will leave the text the same size.
You're welcome!
