AutoCAD 2013/2014/2015
Active Contributor
4 Kudos
Post 1 of 3
MTEXT Edit Select All Text
254 Views, 2 Replies
07-14-2014 12:40 PM
I am curious if there is a way to have MTEXT editor automatically select all the text in the particular item.
I am doing a lot of copy/paste/edit, and every time that I do an MTEXT edit, I first have to hit CTRL-A to select everything in the item.  Is there a command or variable that will automatically select all of the text when I double click the item, so I don't have to keep hitting CTRL-A?
-Dan
67 Kudos
Post 2 of 3
Re: MTEXT Edit Select All Text
07-14-2014 03:32 PM in reply to: dbinkney
I can get you started on a LISP expression.
Go into customization forum and ask how to take this and "Match String" or send to the clipboard...
(cdr (assoc 1 (entget (car (entsel "Select MText object: ")))))
Or a more expanded and somewhat foolproof method [one method]:
(if (setq d (entsel "Select MText object: "))
(if (= (cdr (assoc 0 (entget (car d)))) "MTEXT")
(setq d1 (cdr (assoc 1 (entget (car d)))))
(alert "Object selected not MText. ")
);if
(alert "Nothing selected. ")
);if
You did not mention if you are using LT?
Scot-65
Dyslexia is a permanent physical disability that cannot be seen.
Introverts is proof that there is indeed intelligent life on this planet.
Active Contributor
4 Kudos
Post 3 of 3
07-15-2014 10:00 AM in reply to: scot-65
I'm using Civil 3D 2014 Infrastructure Design Suite Premium.
Thank you very much! I am going to enlist some help with getting the LISP entered, and will let you know if I have any problems.
