AutoCAD 2013/2014/2015
Distinguished Contributor
millermccoy
Message 1 of 8 (281 Views)
Accepted Solution
MS objects in viewports appear blank
281 Views, 7 Replies
06-11-2012 07:16 AM
when I open my .dwg file the viewports are OK, but when I switch tabs then all the viewports in all the tabs are blank
2015 Civil 3D
ktm125 wrote:
thanks
64 bit
I have 17 tabs
What's the best way to copy the tabs to another .dwg?
Can I copy the VPs also?
can I use design center? Yes. It will copy everything in the layouts too, including viewports.
Active Contributor
JonRusk
Message 2 of 8 (275 Views)
Re: MS objects in viewports appear blank
06-11-2012 08:46 AM in reply to: millermccoy
Maybe it's MAXACTVP. Do you have more viewports in your drawing than what that is set at?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18212070&linkID=9240617
Civil 3D 2013 - Windows 7 Pro 64 - Dell T3500 - Xeon 2.67 - 24gb - Quadro 600
millermccoy
Message 3 of 8 (271 Views)
06-11-2012 08:52 AM in reply to: JonRusk
it was set to 64 and I have 37 VPs
2015 Civil 3D
Active Contributor
JonRusk
Message 4 of 8 (269 Views)
06-11-2012 08:55 AM in reply to: millermccoy
I don't know then. The only other time I have seen that is when the drawing needed to be audited.
Active Contributor
JonRusk
Message 5 of 8 (267 Views)
06-11-2012 09:12 AM in reply to: millermccoy
It could be a memory issue. Are you running 32 bit? Just a wild guess. 37 viewports sounds like you have a lot of drawing tabs. We use to have all our drawing sheets for a set in one drawing but started to run into problems, mostly relating to it running excessively slow.
millermccoy
Message 6 of 8 (260 Views)
06-11-2012 09:41 AM in reply to: JonRusk
thanks
64 bit
I have 17 tabs
2015 Civil 3D
Active Contributor
JonRusk
Message 7 of 8 (255 Views)
06-11-2012 09:46 AM in reply to: millermccoy
I don't know much about design center. If it was me I'd copy my drawing 17 times and then delete the other tabs out of each one. There may be a better way.
*Expert Elite*
rkmcswain
Message 8 of 8 (247 Views)
06-11-2012 10:33 AM in reply to: millermccoy
ktm125 wrote:
thanks
64 bit
I have 17 tabs
Post to the Community
New Post
Need installation help?
