AutoCAD Forum
moving images in background in 3d 2014
7 REPLIES 7
Message 1 of 8
PenAndInk
1560 Views, 7 Replies
recently upgraded to 2014 civil 3d. i frequently use images in my drawings as background. i typically send the image to back so that the drawing linework is visible. in 2013 i could select the image to adjust its location and it remained "under" the linework. that is i could use the linework to judge where to locate the image. now in 2014, when i select the image to move it, it comes to the front and i can't see the drawing linework. is there a setting that i need to set to keep the image behind the linework while moving it?
David
7 REPLIES 7
Message 2 of 8
jggerth1
in reply to: PenAndInk
DRAWORDER, select the image, send to BACK
Message 3 of 8
PenAndInk
in reply to: jggerth1
did that. but when i select the image to move it, it still comes above the linework.
Message 4 of 8
braudpat
Hello
Just a quick idea :
SORTENTS = 127  (Default value)
WHIPTHREAD = 1  (and not 2 or 3)
REGENALL
We are speaking about Images in 2D ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 8
PenAndInk
in reply to: braudpat
checked sortents and whipthread, at 127 & 1 respectively.
yes 2d images.
at this poiint i have sent the images to back and sent them under the linewaork but they still come to front on move command.
Message 6 of 8
M_Hensley
Is DRAWORDERCTL set to 3?
Message 7 of 8
PenAndInk
in reply to: M_Hensley
yes DRAWORDERCTL was set at 3. i tries all the other values and got the same result.
Message 8 of 8
PenAndInk
found this is help:
mage selection
You can set an option to draw hatch marks over a selected image. Click Options. Select theDisplay tab. Under Display Performance, set Highlight Raster Image Frame Only to off.
If Highlight Raster Image Frame Only is off, when you select an image, it rises to the top of the display order, obscuring any vectors that cross it. Use the REGEN command to restore the proper display order.
i check the image frame box and now the image stays where it should. just have to remeber to turn the frames off for plots.
thanks for all the responses.
David
th
”Boost
