AutoCAD 2013/2014/2015
Active Member
1 Kudo
Post 1 of 10
Mouse wheel click snap menu?
2564 Views, 9 Replies
08-23-2012 09:08 AM
When zooming, I middle click the mouse to bring up osnaps, then type the letter to force the snap I want.  That stopped working today: the menu pops up, I type "E", the menu goes away, but it doesn't default to endpoint, there's an "E" on my command line.  Any ideas?
I'm not sure if this is a Service Pack 1 issue or not, but I just installed that yesterday.
Thanks!
1,590 Kudos
Post 2 of 10
Re: Mouse wheel click snap menu?
08-23-2012 09:36 AM in reply to: CADragon
Did you change the mouse driver setting for the middle button?
or edit the mouse button setting in CUI command?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
4 Kudos
Post 3 of 10
08-23-2012 09:44 AM in reply to: CADragon
This post has someone with the same issues as us: http://forums.autodesk.com/t5/AutoCAD-2013/SP-1-Is-Available/td-p/3590872
For me, it is when I shift+ right click and hit a hot key.  Funny thing is it only works the first time, every other time it just redirects the key into the command line after closing the menu.  Excel menu hot keys still work fine so it's not a system issue.  I did toggle underlining hot keys in the control panel, and verified the & key is still present in the CUI also.
Active Member
1 Kudo
Post 4 of 10
08-23-2012 09:44 AM in reply to: pendean
I haven't done either of those that I can think of.  Is there a setting you can think of offhand that I could modify in the CUI?
Active Member
1 Kudo
Post 5 of 10
08-23-2012 09:47 AM in reply to: robertstroz8845
Thanks, I did a search, but I couldn't find anything.  Good to know it's not just me.  I knew I shouldn't have applied the SP taht fast, I usually wait a month or two.  That'll teach me!
1,590 Kudos
Post 6 of 10
08-23-2012 12:57 PM in reply to: CADragon
So it broke only after SP1 was installed?
Active Member
1 Kudo
Post 7 of 10
08-23-2012 01:07 PM in reply to: pendean
Yes, that's when I noticed it.  Check the link above that Robert provided, other people are having it, too.
1,590 Kudos
Post 8 of 10
08-23-2012 01:25 PM in reply to: CADragon
Well, they have withdrawn it so maybe they will fix it again. You're looking at a removal and reinstall of 2013 for now.
4 Kudos
Post 9 of 10
09-12-2012 09:19 AM in reply to: pendean
Looks like the latest SP1.1 for x64 win7 has fixed this issue; although, I did not notice it mentioned within the readme.
Rob.
13 Kudos
Post 10 of 10
09-12-2012 11:58 AM in reply to: CADragon
I haven't tried SP1.1 yet (I figured I'd give them a few days to see if they tell us it has fatal flaws first), but I was one of those who installed SP1 when it came out and it did in fact screw up the o-snap shortcuts just as you mentioned. Uninstall SP1 through control panel and it will start working correctly again.
