AutoCAD Forum
Mouse jittering
2 REPLIES 2
284 Views, 2 Replies
Mouse jittering
Installed Autocad 2015 (along with Maya, Revit which are working well)
The problem is that my Cyborg RAT 7 mouse is lagging all over the shop in autocad. Both my trackpad and alternative mouse work fine, so I understand that it's not a graphical problem. I have the appropriate drivers installed.
To be more specific, it seems to lag particularly when I do fast movements. It has trouble keeping up and instead of a smooth sweep I see the cursor in one spot and then in the new spot.
Any ideas why this is?
C
Update: I've found that turning the command line history to 0 somewhat fixes the issues. Although every time I click the mouse lags.
2 REPLIES 2
pendean
Change hardware acceleration in AutoCAD and see if that helps:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Having other Autodesk software installed and running well means nothing: all three of those programs are completely different and share little between them.
in reply to: pendean
Thanks pendean, no I tried that earlier.
I did however uncover the problem. It's to do with how Windows 8.1 handles a high-resolution mouse. It effects some games, and interestingly, Autocad.
http://support.microsoft.com/kb/2908279
”Boost
