AutoCAD Forum
mouse flyout commands
3 REPLIES 3
375 Views, 3 Replies
I have added mirror and isolate to mouse flyout before through CUI... new computer can't remember how I did it. No time to investigate.
you know this list:
erase
move
copy
scale
rotate
draworder
group
I am using AutoCAD 2013... though that is probably irrelevant in this instance.  KUDOS all around
3 REPLIES 3
nestly2
Drag the command into the appropriate Shortcut Menu in the CUI  (ie Default)
Tools->Cusomize->User Interface
Or cui in the command line.
In the top section Roll out Shortcut Menus
There is a Default menu which operates when nothing is selected
And an Edit Menu for when things are selected.
Drag commands from the lower panel into on of these menus.
Thanks I couldn't remeber what it was called.
Its is not called flyout
Shortcut
Edit menu...
”Boost
