AutoCAD 2014, 64 bit. When i open a dwg, all is well. When i open a second drawing it does not open with its own name. It comes in as Drawing1.dwg or Drawing2.dwg and so on as open other drawings.
So if I make any changes to the subsequent drawings, I have to do a saveas for each. Why is this? Why doesn't my drawing come in under it's own name so i can do a qsave and move on?
Thanks!
Jenn
Solved by sthompson1021. Go to Solution.
i think that this case happen if only you make a new CAD drawing by using Ctrl+n which mean that you start a new one.BUT by opening an existing drawing appeared with other name ... this is weird.
Just to give you more information...
This has actually been going on for more than a year now. I installed 2014 on a Windows 7 Home platform 4GB RAM.
I thought upgrading to Windows 7 Ultimate and giving the computer 8GB of RAM would help, but it has not.
So this is the second time I've installed this program and had this same problem.
I open a drawing I'm working on and someone calls to ask question or make changes to another drawing.
I open the second drawing by using the (+ Tab). I'm not creating new drawings, just opening existing ones.
Sometimes I make changes, sometimes I don't, but if I need to save anything, I have to do a SAVEAS because the susequent drawings
come in a Drawing 1... etc.
So I don't see this as a program installation issue. Anyother ideas? A setting I'm missing?
J
I'm using 2014 here as well, using the + tab will result in the behavior you are describing. I think it's programed for new drawings so even if you open a dwg file instead of a dwt file, autocad see's it as a new drawing. I still use classic workspace so I just use the file to open new drawings.
I'm curious how you are opening a specific drawing by using the + Tab button? As far as I know, (left) clicking that button simply opens the template file specified for QNEW.
If you change the "files of type" from dwt to dwg you can navigate to whatever drawing you are looking for.
So, the answer to the OPs issues, is to right click on the +Tab icon, select Open instead of the default New, and browse to the drawing he wants?
No, that still results in drawing 2 or 3... No matter whether you right click or left click it still brings up QNEW in the command line. I don't think you can change the behavior. That's why I said I use the file button to open a new dwg.
edit: I should have checked first. Right clicking and choosing open will let you open a dwg with the right name.
OK, I see it now. If no template is specified for QNEW, then left clicking (+ Tab) causes a QNEW (Select Template) dialog to open, but the selected drawing is still considered a "new" drawing, thus the filename is not retained. Right clicking > Open actually calls the _open command and the selected drawing opens as a drawing, not as a template. I never knew that before because I've never not had a template specified.
interesting -- I;m trying it on C3d 2014, and right clicking gives me a choice of New, Open, Save All, & Close Al. Using Open just open the drawing I select, not Drawing 2 or Drawing 3.
STARTUP sysvar is set to 0
No big deal, upgrading my computer happens every year anyway.
I'll try the new Windows user thing.
OR
Not use the +Tab to open my drawings!
Lol, I guess I'll just open them from the top folder.
Thanks all.
Jenn
I know we kind of got off track a little, but you can use the + tab. You just have to right click and choose open. Then the drawing should open with the right name.
What about using the old-fashioned CTRL-O from the keyboard? Is that passe? CTRL-P, -S, -SHIFT-S helps keep my left hand busy...:-)
What? Remove my hand from the mouse! Unheard of! Lol.
For me,using the top folder icon and not using the TABs, is working best.
Thanks!
jenn
