AutoCAD Forum
Model Space to Paper Space Scaling Issue
6 REPLIES 6
Carsmaniac
526 Views, 6 Replies
HI, I have an issue where when I copy and paste something (a title block in this case) from Model Space to Paper Space the scale gets messed up, and the drawing ends up being much larger than the page, seemingly turning the scale from millimetres to inches. My graphics teacher and I have looked for any setting that may be off, but they all seem to be in order. Is there some sort of quick fix or at least a workaround other than manually scaling all copy-pasted objects? Screenshots of object in Model Space: http://i.imgur.com/0r7PS8T.png (297*210mm) in Paper Space: http://i.imgur.com/olHdChR.png Note: First time posting, sorry if it's in the wrong board/wrong formatting
Tags (3)
6 REPLIES 6
PROH
in reply to: Carsmaniac
Hi. This is a 3dsMax/3dsMaxDesign and your question is about AutoCAD. You better ask in the right forum 🙂
BTW - Paper space scale is set up in Plot Manager.
___________________________________________________________________________________________________
3dsMax 4.2 to 2018
AutoCAD 2000 to 2018
Infrastructure Design Suite Premium 2012 to 2018
Jason.Piercey
Have a look at these system variables in the help files.
INSUNITS
INSUNITSDEFSOURCE
INSUNITSDEFTARGET
GrantsPirate
Use the CHSPACE command rather than copy and paste between MS and PS.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Carsmaniac
I'm using AutoCAD for Mac, so CHSPACE is of no use, and the three variables seem to have no effect.
Thanks for the help so far
nrz13
AutoCAD for Mac forum is here:
http://forums.autodesk.com/t5/autocad-for-mac/ct-p/3011
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
Ron-C
What size is your Titleblock in Model Space ?
What size do you have your layout paper size set to ?
If your titleblock is in model space............it may be to large to copy to your layout page.
just a thought !
”Boost
