I have been using my cosumized menu until I installed autocad 2015.
using "menuload", i can upload my menu in the menu bar BUT:
1) mymenu.mnl doesn't load, hence associated lisp files with my menu dont perform.
2) mymenu disappear from menu bar every time autocad initiated. but it remains in the list of menus and by unload/reload, it will again locate in the menu bar.
3) after loading mymenu, i used to see a .mns file was created in the previous versions of autocad, but not anymore in 2015.
waiting for a solution as it made me mad.
Thank you
PGH
PGH Hi,
1. Next time you better put such a questin in customization DG
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
2. Be sure the mnl file has the exactly the same name as your mnu/cuix file
maybe in the mnl file there are some errors that prevent it from load correctly (try to load it manualy)
3. AutoCAD stopped using mnu/mns files since R2006
Moshe
here is what i found (on the right side of this web page ) that myte help you with this
