I Had saved a file to my desktop as well as my server at work. I origionally started the file in LT and switched to Architecture2013 and then back to LT for my final saves to both locations while at work. I came home a couple hours later and open the file in LT to discover that none of my work was there only the drawing template... then came to work to open the server file using Architecture2013 this time and the same issue...
I tried regenerating, recovering, bak's, checking to make sure all layers were on. When looking at the properties it says the file is 6.23MB, so I can only assume the information is there just hidden?
Hello, We having similar problem. Saving files as usual then when go to open some time later the previous session is not saved. When we look at file thumbnail shows full drawing but when opening file not showing up. Any clues? we running Autocad 2013 on Macpro 8gb ram.
