Could you please help me in using Mcad2DSPreview Control in Autocad Mechanical 2014 VBA. I couldn't find any documentation regarding this.
~Ranjan
Solved by Monster2112. Go to Solution.
sorry to say, you landed in the wrong forum, here is not Mechanical and here is also not VBA handled.
Maybe you have more luck using that forums:
>>>Visual Basic Customization<<<
Good luck, - alfred -
Please post in the right forum next time ; Below is code that you were looking for.
' get mechanical application object
Dim acmApp As AcadmApplication
Set acmApp = ThisDrawing.Application.GetInterfaceObject("AcadmAuto.AcadmApplication")
' get the 2D structure manager object
Dim acmStrMgr As Mcad2DStructureMgr
Set acmStrMgr = acmApp.ActiveDocument.StructureMgr2D
' get all component definitions
Dim acmCompDefs As McadComponentDefinitions
Call acmStrMgr.GetComponentDefinitions(acmCompDefs, False)
' create a folder descriptor
Dim acmFoldDesc As McadFolderDescriptor
Set acmFoldDesc = acmStrMgr.CreateFolderDescriptor
' set it to the folder descriptor
acmFoldDesc.Name = acmCompDefs(0).ComponentViewDefinitions(0).Name
acmFoldDesc.Definition = acmCompDefs(0).ComponentViewDefinitions(0)
' assign it to the preview component
Mcad2DSPreview1.Descriptor = acmFoldDesc
Thank you very much for not making me to wait more time for solution.
I might have lost some more time by moving this query to the relevent forum.
I apprciate your time and help.
Great!
I wish I could be able to give you more Kudos ...!!
