AutoCAD Forum
Match Properties tool
1 REPLY 1
wh15carol
293 Views, 1 Reply
I wonder if I can use the the match properties to tools for font in AutoCad 2013.  I could not in previous versions. has anything changed?
Thank you.
wh15carol
1 REPLY 1
pendean
in reply to: wh15carol
Start the command, and look at the commandline: there is an option called SETTINGS, type it, hit enter, and explore what all the command can do.
Or look up MATCHPROP in Help, then click on the settings link to find out.
Good luck.
”Boost
