Hey Everyone, I'm trying to get this set of surfaces and 3d faces to form a union so that I can export to stl. It will export and be a functional file, however the resulting model as an stl is lacking the surface blends I did to it as a dwg. Does anyone have ideas on how to get the whole model into stl format? Thanks
Katy
You can't export surfaces and faces to an stl file.
stl files are for solids only.. you need to convert / remodel your surfaces / faces into solids.
Maybe this thread will help... http://forums.autodesk.com/t5/AutoCAD-2013-2014-2015/3D-SOLID/td-p/5089170
Mark
You have both solids and infinitely thin surface bodies (can't print something infinitely thin).
You also have solids intersecting solids.
I recommend that you edit the model so that it is more representative of the real world.
I started to fix this up for you and was going to explain how to do it - but as I dug deeper I noticed lack of symmetry that I would expect that left me confused about your true design intent.
Thank you! I am trying to do that now. I want all of those surfaces to come to a point there so that there are ridges. Once they are surfaces, they cannot be stretched however, so I'm have a hard time doing that. I'm also having a hard time converting the surfaces to solids now. I feel like no matter how close I get there is always something else wrong! haha
