Can someone help me with making a hatch pattern.
I have the following code:
* Bandraster, Bandraster type Inteco
0, 0, 0, 0, 100
90, 0, 0, 0, 3000, 100, -100
90, 0, 100, 0, 600, 1600 -1600
The first horizontal line is to be at 100 mm, and the second horizontal line is then to arrive at a distance of 1600 mm
In between are at a distance of 600 the vertical lines.
I can not get it together to get the second horizontal line at a distance of 1600.
Solved by jostroopers. Go to Solution.
I have the code for the script.
*Bandraster, bandraster 100-1250-500
90, 0,0, 0,1700
90, 100,0, 0,1700
0, 100, 0, 0,600, 1600, -100
