unfortunately due to my mistake all of my cad work till date got deleted bt some of projects as i worked while m y net was on it was being also on autodesk 360 so my request is that can i dwnld my work from autodesk 360....
Solved by Terryzin. Go to Solution.
Hi aarifmalik,
If you use Autodesk 360 to synchronize your data, you probably can find them back from Trash.
1. Click right mouse button on Autodesk 360 tray -> Launch Autodesk 360 web
2. Click Trash from the left panel of the web page.
3. Restor the files.
4. Autodesk 360 will synchroize your data back to your local disk.
-Terry
