Show only
Search instead for
Check whether you unloaded the main acad cui. To do it type cuiload and see if in the loaded cui's acad is loaded. If not there should be plenty of documentation online about the location of the acad.cui for you to load. You might also be able to automatically reload it by reloading your workspace, I don't remember.
Patrice ( Supporting Troops ) - Autodesk Expert Elite If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Thank you For all those in the Community, I downloaded the "pdfin" plugin. When doing this the ribbon and other menus are deleted from the autocad drawing file. tfleig
