AutoCAD 2013/2014/2015
MrCADDMan
Message 1 of 11 (915 Views)
Long Saving Time
915 Views, 10 Replies
11-05-2012 10:42 AM
Hello Everyone,
We are experiencing a problem saving on AutoCAD 2013.
All our files are saved on a local network file server. Teh drawings are not complex drawings, only basic 2D work, blocks and no more than 5 nested xrefs on extreme cases. May contain some images attached but all saved in the current job folder.
Some drawings may take up to 2 minutes to save.
Does anyone have a clue or experienced this situation?
Any support is greatly appreciated.
Lucio Da Silva
*Expert Elite*
DarrenP
Message 2 of 11 (911 Views)
Re: Long Saving Time
11-05-2012 11:47 AM in reply to: MrCADDMan
what happens if you save locally?
MrCADDMan
Message 3 of 11 (908 Views)
11-05-2012 11:56 AM in reply to: DarrenP
Still takes long.
Our support files search parh have some network paths. After I loaded standard AutoCAD profile the saving time reduced a lot. Interesting that this did not happen on previous releases.
Lucio Da Silva
sabrown
Message 4 of 11 (826 Views)
12-18-2012 10:07 AM in reply to: MrCADDMan
We are having the same issues, does not matter the autocad based product, local or network (wihin seconds of each other).  Wondering if it is due to norton antivirus, but we arn't allowed to turn it off.  Huge time waster ofver just a day.  Sorry I don't have a solution.
*Expert Elite*
Alfred.NESWADBA
Message 5 of 11 (819 Views)
12-18-2012 10:18 AM in reply to: sabrown
You don't need to disable it, just configure it to not scan the DWG- and DXF-files. And do that locally + on your server antivirus package.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
imadhabash
Message 6 of 11 (803 Views)
12-18-2012 09:09 PM in reply to: Alfred.NESWADBA
Try one of the following or both :
1- Cancel any transperancy setting for the commnad line , leave it normal.
2- SAVEFIDELITY = 0 .
i'm sure you'll see different ( i hope ). :smileyhappy:
Best Regards,
Imad Habash
Amman,Jordan
Please mark this as the solution if it resolves your issue.Kudos gladly accepted. ⇘
Valued Mentor
KLYPHY
Message 7 of 11 (791 Views)
12-19-2012 06:56 AM in reply to: MrCADDMan
We found that when the Thumbnail Previews are updated with each SAVE, it can take up to 10 minutes.
So, we made lisps that set UPDATETHUMBNAIL to "0" and to "31".
We keep it set to "0".
When we want an updated Thumbnail, we execute "TN31" and save.
Then immediately "TN0" to set it back to "0" for quicker saves.
This may help in your case.
Read Ya Later -KLYPH
sabrown
Message 8 of 11 (731 Views)
01-15-2013 06:07 PM in reply to: Alfred.NESWADBA
Thanks, but that is also not allowed through policy settings. Thanks, Shane This electronic message contains information generated by the USDA solely for the intended recipients. Any unauthorized interception of this message or the use or disclosure of the information it contains may violate the law and subject the violator to civil or criminal penalties. If you believe you have received this message in error, please notify the sender and delete the email immediately.
MrCADDMan
Message 9 of 11 (731 Views)
01-15-2013 06:07 PM in reply to: KLYPHY
I have updatethumbnail set to 0 already, but I am investigating if the Antivirus is trigering the problem. I will keep posted. Thanks, Lucio
Lucio Da Silva
sabrown
Message 10 of 11 (731 Views)
01-15-2013 06:07 PM in reply to: imadhabash
SAVEFIDELITY was the answer for dropping save times by a factor of 10-40 times on different computers and different files. Impressive. I will have to look for a workaround to help with all the annotative attributes, we will have to see what grief we experience. Thanks, Shane This electronic message contains information generated by the USDA solely for the intended recipients. Any unauthorized interception of this message or the use or disclosure of the information it contains may violate the law and subject the violator to civil or criminal penalties. If you believe you have received this message in error, please notify the sender and delete the email immediately.
Post to the Community
New Post
Need installation help?
