AutoCAD 2013/2014/2015
Member
0 Kudos
Post 1 of 3
long regens when switching from model to paper space
283 Views, 2 Replies
04-25-2013 06:38 AM
Just installed 2014 and the time it takes to switch from model space to paper space in a simple drawing is 3 times what it took in 2011.
can anyone tell me how to speed this process up?
Is there stuff running in the background in Autocad that makes it slower?
Had this same issue when we looked at 2013 as well.
259 Kudos
Post 2 of 3
Re: long regens when switching from model to paper space
04-25-2013 07:18 AM in reply to: cbdavis7
Hello
It always take time to switch for the 1st time from Tab / Model to any other Tab / Layout !
Because ACAD has to buid the display list of this Tab / Model / Layout ...
But this is controlled by the System Var : LAYOUTREGENCTL
Default and Normal Value = 2
But even with 2, you could have to wait when you have just load a DWG
and you switch for the 1st time to any other Tab !!
Bye, Pat
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
1,210 Kudos
Post 3 of 3
04-25-2013 12:14 PM in reply to: cbdavis7
just to make sure a few questions:
  - have you migrated your settings?
  - have you verified that the page-setup and the CTB/STB-files for each layout is valid for 2014?
- alfred -
Alfred NESWADBA
