AutoCAD Forum
Lofting Problems
1 REPLY 1
338 Views, 1 Reply
Lofting Problems
I am trying to loft a triangle around the path of a helix. I want the top point of the triangle to be facing in such that the ouside surface is flat (in the veritcal direction) for the entire helix and I have the two triangle cross sections oriented to do as much.  Whenever I try loft it, autocad associates sides of the triangle that aren't supposed to connect causing the triangle to twist along the path.  Is there a way that I can easily tell autocad which sides I want to connect?
1 REPLY 1
JDMather
Guide curves mapping point to point.
Is there any reason you aren't using Sweep?
http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%204.pdf
Attach your dwg file here.
”Boost
