AutoCAD 2013/2014/2015
Active Member
acqualife
Message 1 of 4 (163 Views)
Lofting ellipse question
163 Views, 3 Replies
10-12-2012 09:42 PM
Okay so is there anyway to enter the whole equation of an ellipse into autocad and it will map it? ex x^2/a^2+y^2/b^2+z^2/c^2=1 with different values for x y z a b c. I want to generate different ellipses and then loft them togather? Is there an eaiser way? Also is there a good tutrial series any would recommend? I just want one the starts with the basics and goes all the way to the move advance stuff.
*Expert Elite*
JDMather
Message 2 of 4 (151 Views)
Re: Lofting ellipse question
10-13-2012 06:04 AM in reply to: acqualife
Do you know the major and minor axis lengths?
Can't you use the Ellipse command?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
acqualife
Message 3 of 4 (143 Views)
10-13-2012 10:26 AM in reply to: JDMather
The length in the x direction needs to be 20 the length in the y direction needs to be 10 for instance. Also i need a length in the z direction to be 30. So i guess i need to stretch it in the x direction. The thing about the ellipse command is i have no control on the lenght in the x direction- i guessing the width.
*Expert Elite*
JDMather
Message 4 of 4 (132 Views)
10-13-2012 05:47 PM in reply to: acqualife
An ellipse is a planar object.
You should have complete and absolute control.
Attach your file here.
You might attach a scan of a sketch of what you are trying to create.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
