AutoCAD 2013/2014/2015
Active Member
0 Kudos
Post 1 of 4
Lofting ellipse question
164 Views, 3 Replies
10-12-2012 09:42 PM
Okay so is there anyway to enter the whole equation of an ellipse into autocad and it will map it? ex x^2/a^2+y^2/b^2+z^2/c^2=1 with different values for x y z a b c. I want to generate different ellipses and then loft them togather? Is there an eaiser way? Also is there a good tutrial series any would recommend? I just want one the starts with the basics and goes all the way to the move advance stuff.
2,129 Kudos
Post 2 of 4
Re: Lofting ellipse question
10-13-2012 06:04 AM in reply to: acqualife
Do you know the major and minor axis lengths?
Can't you use the Ellipse command?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Member
0 Kudos
Post 3 of 4
10-13-2012 10:26 AM in reply to: JDMather
The length in the x direction needs to be 20 the length in the y direction needs to be 10 for instance. Also i need a length in the z direction to be 30. So i guess i need to stretch it in the x direction. The thing about the ellipse command is i have no control on the lenght in the x direction- i guessing the width.
2,129 Kudos
Post 4 of 4
10-13-2012 05:47 PM in reply to: acqualife
An ellipse is a planar object.
You should have complete and absolute control.
Attach your file here.
You might attach a scan of a sketch of what you are trying to create.
