I am attempting to create rotor blades, following this youtbue tutorial, althougth adjusting the dimentions and shapes to my preferences
https://www.youtube.com/watch?v=4vGiSv5RrFU
I am attempting to create a 3D shape with the loft command, but it doesn't seem to be working. After selecting the two shapes I am trying to loft, nothing happens. I've also tried the extrude command on the shape, however, it only results in a hollow 3D shape. How can I fill in the shape? (the one I want to fill in is the long leaf shaped one) And in a way that I can later intersect it with the larger round plate like shape. Any help would be appreciated. Thanks 🙂
PS: This is on autocad for mac 2015
To use the same procedure as shown in the video, you need to THICKEN the helical disc..
To LOFT or EXTRUDE the "leaf" as a solid object, you need to close the profile so it's a Closed Polyline. Also, I would avoid GROUPing objects (upper "leaf")
I attempted the thicken command on the disk, but it didn't seem to do anything, not even an error message. Is there something wrong with the disk?
Are you sure there's no error ... like this?
Command: THICKEN Select surfaces to thicken: 1 found Select surfaces to thicken: Specify thickness <5.0000>: 7 Modeling Operation Error: No loop through new edges and vertices. 1 surface cannot be thickened with specified value. Object intersects itself.
I think you won't be able to thicken over ~6 units because the thickened object would cross back across the center of the disk. If you need the disk to be more than 6 units, try starting with a larger helix radius.
Thank you! I was able to thicken the disk, using the smaller units. However, when extruding the leaf shape, it was still hollow on the inside. I'm not sure how to make it a closed polyline, besides triming it other half of the circle so that it's a single shape that's being extruded
Are you familiar with the Polyline Edit (PE) command with Join option?
Are you familiar with the Join command?
What if you use the Presspull command rather than Extrude command?
I am not familiar with the Polyline edit command, however I used the presspull command to successfully bring up the leaf shape in SD, filled. To do so I had to presspull the two haves of the leaf since it considered that to be two shapes, as separated by the line in the center. After doing so I could not join the two halves together and could not go through with the Intersect command. Is there some way I can fix that? I have attached the file with the updated attempts. Sorry I am having so much trouble with this simple thing >.<
Sub Use_Loft_in_VBA
Dim dq As String
Dim enter As String
Dim Lw1 As AcadLWPolyline
Dim Lw2 As AcadLWPolyline
Dim s1 As String, s2 As String
Dim Text As String
enter = vbCr
dq = Chr(34)
DelALL
'draw close polyline at elevation 0
ThisDrawing.SendCommand "_rec 0,0,0 5000,5000,0 "
'draw close polyline at elevation 1000
Set Lw1 = LastEntityinModelSpace
ThisDrawing.SendCommand "_rec 1000,1000,1000 4000,4000,1000 "
Set Lw2 = LastEntityinModelSpace
Text = "_loft " & "(handent " & _
dq & Lw1.Handle & dq & ") " & "(handent " & dq & Lw2.Handle & dq & ") " & enter & enter
ThisDrawing.SendCommand Text
ZoomExtents
End Sub
Public Function LastEntity(Container As AcadBlock) As AcadEntity
Set LastEntity = Container(Container.count - 1)
End Function
Function LastEntityinModelSpace() As AcadEntity
Set LastEntityinModelSpace = LastEntity(ThisDrawing.ModelSpace)
End Function
