Hello, I was wondering if points from a total station can be loaded into AutoCAD 2015 to create a surface? We are looking to do site plans for farming applications in 3D showing land elevations and structures.
Jerry
Solved by dgorsman. Go to Solution.
Kinda-sorta-maybe. Load points? Probably, with a simple script. Your total station manufacturer may provide an AutoCAD add-in to help with that. Load points with data? Probably not, without some customization; might be better off with Map3D. Create a surface? Nope; you will definitely need Civil3D or a third-party tool.
