AutoCAD Forum
Load survey points in AutoCAD 2015
3 REPLIES 3
jerry
339 Views, 3 Replies
Hello, I was wondering if points from a total station can be loaded into AutoCAD 2015 to create a surface?  We are looking to do site plans for farming applications in 3D showing land elevations and structures.
Jerry
3 REPLIES 3
dgorsman
in reply to: jerry
Kinda-sorta-maybe.  Load points?  Probably, with a simple script.  Your total station manufacturer may provide an AutoCAD add-in to help with that.  Load points with data?  Probably not, without some customization; might be better off with Map3D.  Create a surface?  Nope; you will definitely need Civil3D or a third-party tool.
rkmcswain
in reply to: jerry
What @dgorsman said.
I'll throw out a plug for MapWorks, an affordable add on for plain AutoCAD that should do what you want.
http://www.dotsoft.com/mapworks.htm
R.K. McSwain     | CADpanacea | on twitter
jerry
in reply to: jerry
Thanks for you info, I will look into the add on program.
”Boost
