AutoCAD Forum
Lisp for replacing block with point?
3 REPLIES 3
felt33
486 Views, 3 Replies
It would be so so great if Autodesk would make the "Replace Block" command actually do aomething. I can replace parts in Solidworks without issue, but in a much simpler 2D environment, replacing blocks is next to impossible unless it's a block of a very very simple shape or something. Could be a great asset if they got it working correctly.
3 REPLIES 3
3wood
in reply to: felt33
Would you mind post a sample drawing so we can test it?
Kent1Cooper
in reply to: felt33
In what way does it not do what you expect?  What do you do, and what actually happens?
In your posting of the same question in the 2007/8/9 Forum, you don't include the "with point" part in the Subject line.  You should be able to use my suggestions there [or presumably AutoCAD's BlockReplace] with a Block that contains only a Point.  But if you want to replace Blocks with Point entities, that should be simple enough to work out, for example as a modification of one or both of the commands in my BlockReplace.lsp file.  Is that worth pursuing?
Kent Cooper, AIA
shavezkhan
in reply to: felt33
HAVE YOU USED  BLOCK REPLACE COMMAND
THIS ONE ALSO WE CAN USE ..
”Boost
