AutoCAD Forum
LISP Error, need help
6 REPLIES 6
wsargent
739 Views, 6 Replies
Our survey department neets to add mtext that is justified middle center with a zero width. I have not used LISP resently and cannot figure out what I am missing.
(defun C:lbl ()
   (command "-mtext" pause                                    ; Activates mtext command
      "Columns" "N"                                                   ; Removes columns
      "Justify" "MC"                                                    ; Middle-center justified
      "Width" "0"                                                       ; zero width
When I run this command I get this output at the command line:
Command: lbl
-mtext Current text style:  "SIMPLEX"  Text height:  0.0600  Annotative:  No
Specify first corner:
Specify opposite corner or [Height/Justify/Line
spacing/Rotation/Style/Width/Columns]: Columns
Enter column type [Dynamic/Static/No columns] <Dynamic>: No columns
Invalid option keyword.
; error: Function cancelled
__________
AutoCAD Civil 3D 2016 SP3.0, built on: AutoCAD 2016 SP1, Map 3D 2016 SP2
Dell Percision T5810: MS Windows 10 Pro; Intel Xeon CPU E5-1620 v3 @ 3.50 GHz, 16.00 GB RAM, NVIDIA K2200 4.00 GB Memory
Tags (1)
6 REPLIES 6
dmfrazier
in reply to: wsargent
In testing out your code on the command line I have discovered (to my surprise!) that the MTEXT (actually -MTEXT) command options ([Height/Justify/Line spacing/Rotation/Style/Width/Columns]) apparently don't work at all.  (I am running 2013.)
You might be able to set some (or all) of the settings outside the MTEXT command.  For instance, the default column setting is stored in the MTEXTCOLUMN system variable.  I can't find SysVars for the other two, but maybe someone else will chime in with methods for setting those ahead of the command (or modifying them after).
wsargent
Thanks for the system varable. That helped with the script.
I found that setting the width and columns was causing problems. I removed the width and set the colums using the system varable.
Not what we wanted, but it works.
__________
Balaji_Ram
Good to know that you have it working using the system variable which was suggested by dmfrazier.
I have tried the lisp code in AutoCAD 2012 and 2013 and it worked ok.
Can you try pasting the lisp statement directly in the AutoCAD command line window and see if it reports the same error message ?
(command "-mtext" pause "Columns" "N" "Justify" "MC" "Width" "0")
Also, can you provide the same inputs using the command line ? Does that work ?
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
wsargent
in reply to: Balaji_Ram
When I enter the script into the command line I get the following:
Command: (command "-mtext" pause "Columns" "N" "Justify" "MC" "Width" "0")
-mtext Current text style:  "SIMPLEX"  Text height:  3.6000  Annotative:  Yes
spacing/Rotation/Style/Width/Columns]: Justify
Enter justification [TL/TC/TR/ML/MC/MR/BL/BC/BR] <TL>: MC
spacing/Rotation/Style/Width/Columns]: Width
Specify width: 0
MText: nil
MText: *Cancel*
If I manually enter the information one step at a time it works:
Command: -MTEXT
spacing/Rotation/Style/Width/Columns]: c
Enter column type [Dynamic/Static/No columns] <Dynamic>: n
spacing/Rotation/Style/Width/Columns]: j
Enter justification [TL/TC/TR/ML/MC/MR/BL/BC/BR] <TL>: mc
spacing/Rotation/Style/Width/Columns]: w
Specify width: 0
MText: example
__________
dmfrazier
Your single line of LISP code does work for me in 2013 (though it is awkward as there are no prompts):
   Current text style:  "2thirds"  Text height:  0.0938  Annotative:  No
   nil
   MText: THIS IS MTEXT
   MText: NEW LINE
   MText:
   Command:
Trying the OP's function again, today, it also works!
I'm not sure what's different today compared to my original test, but now even when I run -MTEXT on the command line I am able to get the various command options to respond.
Strange...
dmfrazier
Just a hunch - I notice your text style is annotative.  When you run on the command line, are you presented at any point with a prompt (dialog box) to select a scale?
”Boost
