I have 2 LISP routines that i use very often. I'd like to combine the two so that I can work a bit faster. One is the "CountBlock" routine. This LISP counts all the blocks in my drawing and makes a table showing how many of each block there is my drawing. The other is the "LengthByLayer" which gives me the total length of all the polylines in a layer. What I'm trying to do is get the CountBlock LISP to also count footages like the LengthByLayer LISP. Any help please?
LengthByLayer:
(defun c:lbl ( / ss la rv i tv op en) (while (not ss) (princ "\nPick any object on the required layer") (setq ss (ssget))) (initget "Length Area") (setq rv "Length") (and (not rv) (setq rv "Area")) (setq la (cdr (assoc 8 (entget (ssname ss 0)))) ss (ssget "X" (list (cons 0 "*POLYLINE") (cons 8 la))) i (sslength ss) tv 0 op 0) (while (not (minusp (setq i (1- i)))) (setq en (ssname ss i)) (command "_.AREA" "_E" en) (cond ((= rv "Length") (setq tv (+ tv (getvar "PERIMETER")))) (T (setq tv (+ tv (getvar "AREA"))) (if (/= (logand (cdr (assoc 70 (entget en))) 1) 1) (setq op (1+ op)))))) (alert (strcat "\nTotal " rv " for layer " la " = " (rtos tv 2 2) " in " (itoa (sslength ss)) " polylines\n" (if (/= rv "Length") (strcat (itoa op) " with open polylines") ""))) (prin1))
CountBlock:
(setq count:version "1-4" count:defaults '( (out "tab") (tg1 "1") (tg2 "1") (tg3 "1") (ed1 "Block Data") (ed2 "Preview") (ed3 "Block Name") (ed4 "Count") (srt "blk") (ord "asc") ) ) ;;----------------------------------------------------------------------;; (defun count:fixdir ( dir ) (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir)) ) ;;----------------------------------------------------------------------;; (defun count:getsavepath ( / tmp ) (cond ( (setq tmp (getvar 'roamablerootprefix)) (strcat (count:fixdir tmp) "\\Support") ) ( (setq tmp (findfile "acad.pat")) (count:fixdir (vl-filename-directory tmp)) ) ( (count:fixdir (vl-filename-directory (vl-filename-mktemp)))) ) ) ;;----------------------------------------------------------------------;; (setq count:savepath (count:getsavepath) ;; Save path for DCL & Config files count:dclfname (strcat count:savepath "\\LMAC_count_V" count:version ".dcl") count:cfgfname (strcat count:savepath "\\LMAC_count_V" count:version ".cfg") ) ;;----------------------------------------------------------------------;; (defun c:count ( / *error* all col des dir ed1 ed2 ed3 ed4 fil fnm fun hgt idx ins lst ord out row sel srt tab tg1 tg2 tg3 tmp xrf ) (defun *error* ( msg ) (if (= 'file (type des)) (close des) ) (if (and (= 'vla-object (type tab)) (null (vlax-erased-p tab)) (= "AcDbTable" (vla-get-objectname tab)) (vlax-write-enabled-p tab) ) (vla-put-regeneratetablesuppressed tab :vlax-false) ) (if (and (= 'vla-object (type count:wshobject)) (not (vlax-object-released-p count:wshobject)) ) (progn (vlax-release-object count:wshobject) (setq count:wshobject nil) ) ) (count:endundo (count:acdoc)) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))) (princ (strcat "\nError: " msg)) ) (princ) ) (if (not (findfile count:cfgfname)) (count:writecfg count:cfgfname (mapcar 'cadr count:defaults)) ) (count:readcfg count:cfgfname (mapcar 'car count:defaults)) (foreach sym count:defaults (if (not (boundp (car sym))) (apply 'set sym)) ) (if (and (= "tab" out) (not (vlax-method-applicable-p (vla-get-modelspace (count:acdoc)) 'addtable))) (setq out "txt") ) (count:startundo (count:acdoc)) (while (setq tmp (tblnext "block" (null tmp))) (if (= 4 (logand 4 (cdr (assoc 70 tmp)))) (setq xrf (vl-list* "," (cdr (assoc 2 tmp)) xrf)) ) ) (if xrf (setq fil (list '(0 . "INSERT") '(-4 . "<NOT") (cons 2 (apply 'strcat (cdr xrf))) '(-4 . "NOT>"))) (setq fil '((0 . "INSERT"))) ) (cond ( (null (setq all (ssget "_X" fil))) (count:popup "No Blocks Found" 64 (princ "No blocks were found in the active drawing.") ) ) ( (and (= "tab" out) (= 4 (logand 4 (cdr (assoc 70 (tblsearch "layer" (getvar 'clayer))))))) (count:popup "Current Layer Locked" 64 (princ "Please unlock the current layer before using this program.") ) ) ( (progn (setvar 'nomutt 1) (princ "\nSelect blocks to count <all>: ") (setq sel (cond ( (null (setq sel (vl-catch-all-apply 'ssget (list fil)))) all ) ( (null (vl-catch-all-error-p sel)) sel ) ) ) (setvar 'nomutt 0) (null sel) ) ) ( (or (= "com" out) (and (= "tab" out) (setq ins (getpoint "\nSpecify point for table: "))) (and (/= "tab" out) (setq fnm (getfiled "Create Output File" (cond ( (and (setq dir (getenv "LMac\\countdir")) (vl-file-directory-p (setq dir (count:fixdir dir))) ) (strcat dir "\\") ) ( (getvar 'dwgprefix)) ) out 1 ) ) ) ) (repeat (setq idx (sslength sel)) (setq lst (count:assoc++ (count:effectivename (ssname sel (setq idx (1- idx)))) lst)) ) (if (= "blk" srt) (setq fun (eval (list 'lambda '( a b ) (list (if (= "asc" ord) '< '>) '(strcase (car a)) '(strcase (car b)))))) (setq fun (eval (list 'lambda '( a b ) (list (if (= "asc" ord) '< '>) '(cdr a) '(cdr b))))) ) (setq lst (vl-sort lst 'fun)) (cond ( (= "com" out) (defun prinn ( x ) (princ "\n") (princ x)) (prinn (count:padbetween "" "" "=" 60)) (if (= "1" tg1) (progn (prinn ed1) (prinn (count:padbetween "" "" "-" 60)) ) ) (prinn (count:padbetween ed3 ed4 " " 55)) (prinn (count:padbetween "" "" "-" 60)) (if (= "1" tg3) (foreach itm lst (prinn (count:padbetween (car itm) (itoa (cdr itm)) "." 55)) ) (foreach itm lst (prinn (car itm))) ) (prinn (count:padbetween "" "" "=" 60)) (textpage) ) ( (= "tab" out) (if (= "1" tg3) (setq lst (mapcar '(lambda ( x ) (list (car x) (itoa (cdr x)))) lst)) (setq lst (mapcar '(lambda ( x ) (list (car x))) lst)) ) (setq hgt (vla-gettextheight (vla-item (vla-item (vla-get-dictionaries (count:acdoc)) "acad_tablestyle") (getvar 'ctablestyle) ) acdatarow ) ) (setq tab (vla-addtable (vlax-get-property (count:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)) (vlax-3D-point (trans ins 1 0)) (+ (length lst) 2) (+ 1 (atoi tg2) (atoi tg3)) (* 2.5 hgt) (* hgt (max (apply 'max (mapcar 'strlen (append (if (= "1" tg2) (list ed2)) (if (= "1" tg3) (list ed4)) (cons ed3 (apply 'append lst)) ) ) ) (if (= "1" tg1) (/ (strlen ed1) (+ 1 (atoi tg2) (atoi tg3))) 0) ) ) ) ) (vla-put-regeneratetablesuppressed tab :vlax-true) (vla-put-stylename tab (getvar 'ctablestyle)) (setq col 0) (mapcar '(lambda ( a b ) (if (= "1" a) (progn (vla-settext tab 1 col b) (setq col (1+ col))))) (list tg2 "1" tg3) (list ed2 ed3 ed4) ) (setq row 2) (foreach itm lst (if (= "1" tg2) (count:setblocktablerecord tab row (setq col 0) (car itm)) (setq col -1) ) (foreach txt itm (vla-settext tab row (setq col (1+ col)) txt) ) (setq row (1+ row)) ) (if (= "1" tg1) (vla-settext tab 0 0 ed1) (vla-deleterows tab 0 1) ) ) ( (setenv "LMac\\countdir" (count:fixdir (vl-filename-directory fnm))) (if ( (if (= "txt" out) count:writetxt count:writecsv ) (append (if (= "1" tg1) (list (list ed1)) ) (if (= "1" tg3) (cons (list ed3 ed4) (mapcar '(lambda ( x ) (list (car x) (itoa (cdr x)))) lst)) (cons (list ed3) (mapcar '(lambda ( x ) (list (car x))) lst)) ) ) fnm ) (princ (strcat "\nBlock data written to " fnm)) (count:popup "Unable to Create Output File" 48 (princ (strcat "The program was unable to create the following file:\n\n" fnm "\n\nPlease ensure that you have write-permissions for the above directory." ) ) ) ) ) ) ) ) (*error* nil) (princ) ) ;;----------------------------------------------------------------------;; (defun c:countsettings ( / *error* dch des ord out out-fun srt tg1 tg1-fun tg2 tg2-fun tg3 tg3-fun ) (defun *error* ( msg ) (if (= 'file (type des)) (close des) ) (if (and (= 'int (type dch)) (< 0 dch) ) (unload_dialog dch) ) (if (and (= 'vla-object (type count:wshobject)) (not (vlax-object-released-p count:wshobject)) ) (progn (vlax-release-object count:wshobject) (setq count:wshobject nil) ) ) (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))) (princ (strcat "\nError: " msg)) ) (princ) ) (if (not (findfile count:cfgfname)) (count:writecfg count:cfgfname (mapcar 'cadr count:defaults)) ) (count:readcfg count:cfgfname (mapcar 'car count:defaults)) (foreach sym count:defaults (if (not (boundp (car sym))) (apply 'set sym)) ) (cond ( (not (count:writedcl count:dclfname)) (count:popup "DCL file could not be written" 48 (princ (strcat "The DCL file required by this program could not be written to the following location:\n\n" count:dclfname "\n\nPlease ensure that you have write-permissions for the above directory." ) ) ) ) ( (<= (setq dch (load_dialog count:dclfname)) 0) (count:popup "DCL file could not be loaded" 48 (princ (strcat "The following DCL file required by this program could not be loaded:\n\n" count:dclfname "\n\nPlease verify the integrity of this file." ) ) ) ) ( (not (new_dialog "dia" dch)) (count:popup "DCL file contains an error" 48 (princ (strcat "The program dialog could not be displayed as the following DCL file file contains an error:\n\n" count:dclfname "\n\nPlease verify the integrity of this file." ) ) ) ) ( t (set_tile "dcl" (strcat "Count.lsp Version " (vl-string-translate "-" "." count:version) " \\U+00A9 Lee Mac " (menucmd "m=$(edtime,0,yyyy)") ) ) (if (and (= "tab" out) (not (vlax-method-applicable-p (vla-get-modelspace (count:acdoc)) 'addtable))) (progn (mode_tile "tab" 1) (setq out "txt") ) ) ( (setq tg1-fun (lambda ( val ) (mode_tile "ed1" (- 1 (atoi (setq tg1 val)))))) (set_tile "tg1" tg1)) (action_tile "tg1" "(tg1-fun $value)") ( (setq tg2-fun (lambda ( val ) (mode_tile "ed2" (- 1 (atoi (setq tg2 val)))))) (set_tile "tg2" tg2)) (action_tile "tg2" "(tg2-fun $value)") ( (setq tg3-fun (lambda ( val ) (mode_tile "ed4" (- 1 (atoi (setq tg3 val)))))) (set_tile "tg3" tg3)) (action_tile "tg3" "(tg3-fun $value)") (foreach key '("ed1" "ed2" "ed3" "ed4") (set_tile key (eval (read key))) (action_tile key (strcat "(setq " key " $value)")) ) (set_tile out "1") ( (setq out-fun (lambda ( val ) (if (= "tab" (setq out val)) (progn (mode_tile "tg2" 0) (mode_tile "ed2" (- 1 (atoi tg2))) ) (progn (mode_tile "tg2" 1) (mode_tile "ed2" 1) ) ) ) ) out ) (foreach key '("tab" "txt" "csv" "com") (action_tile key "(out-fun $key)") ) (set_tile srt "1") (foreach key '("blk" "qty") (action_tile key "(setq srt $key)") ) (set_tile ord "1") (foreach key '("asc" "des") (action_tile key "(setq ord $key)") ) (if (= 1 (start_dialog)) (count:writecfg count:cfgfname (mapcar 'eval (mapcar 'car count:defaults))) ) ) ) (*error* nil) (princ) ) ;;----------------------------------------------------------------------;; (defun count:popup ( ttl flg msg / err ) (setq err (vl-catch-all-apply 'vlax-invoke-method (list (count:wsh) 'popup msg 0 ttl flg))) (if (null (vl-catch-all-error-p err)) err ) ) ;;----------------------------------------------------------------------;; (defun count:wsh nil (cond (count:wshobject) ((setq count:wshobject (vlax-create-object "wscript.shell")))) ) ;;----------------------------------------------------------------------;; (defun count:tostring ( arg / dim ) (cond ( (= 'int (type arg)) (itoa arg) ) ( (= 'real (type arg)) (setq dim (getvar 'dimzin)) (setvar 'dimzin 8) (setq arg (rtos arg 2 15)) (setvar 'dimzin dim) arg ) ( (vl-prin1-to-string arg)) ) ) ;;----------------------------------------------------------------------;; (defun count:writecfg ( cfg lst / des ) (if (setq des (open cfg "w")) (progn (foreach itm lst (write-line (count:tostring itm) des)) (setq des (close des)) t ) ) ) ;;----------------------------------------------------------------------;; (defun count:readcfg ( cfg lst / des itm ) (if (and (setq cfg (findfile cfg)) (setq des (open cfg "r")) ) (progn (foreach sym lst (if (setq itm (read-line des)) (set sym (read itm)) ) ) (setq des (close des)) t ) ) ) ;;----------------------------------------------------------------------;; (defun count:writedcl ( dcl / des ) (cond ( (findfile dcl)) ( (setq des (open dcl "w")) (foreach itm '( "//--------------------=={ Count Dialog Definition }==-------------------//" "// //" "// Dialog definition file for use in conjunction with Count.lsp //" "//----------------------------------------------------------------------//" "// Author: Lee Mac, Copyright © 2014 - www.lee-mac.com //" "//----------------------------------------------------------------------//" "" "b15 : edit_box" "{" " edit_width = 16;" " edit_limit = 1024;" " fixed_width = true;" " alignment = centered;" " horizontal_margin = none;" " vertical_margin = none;" "}" "b30 : edit_box" "{" " edit_width = 52;" " edit_limit = 1024;" " fixed_width = true;" " alignment = centered;" " horizontal_margin = none;" " vertical_margin = none;" "}" "tog : toggle" "{" " vertical_margin = none;" " horizontal_margin = 0.2;" "}" "rwo : row" "{" " fixed_width = true;" " alignment = centered;" "}" "rrw : radio_row" "{" " fixed_width = true;" " alignment = centered;" "}" "dia : dialog" "{" " key = \"dcl\";" " spacer_1;" " : boxed_column" " {" " label = \"Output\";" " : rrw" " {" " : radio_button { key = \"tab\"; label = \"Table\"; }" " : radio_button { key = \"txt\"; label = \"Text File\"; }" " : radio_button { key = \"csv\"; label = \"CSV File\"; }" " : radio_button { key = \"com\"; label = \"Command line\"; }" " }" " spacer;" " }" " : boxed_column" " {" " label = \"Headings\";" " spacer_1;" " : rwo" " {" " : tog { key = \"tg1\"; }" " : b30 { key = \"ed1\"; }" " : spacer" " {" " fixed_width = true;" " vertical_margin = none;" " width = 2.5;" " }" " }" " : rwo" " {" " spacer;" " : tog { key = \"tg2\"; }" " : b15 { key = \"ed2\"; }" " : b15 { key = \"ed3\"; }" " : b15 { key = \"ed4\"; }" " : tog { key = \"tg3\"; }" " spacer;" " }" " spacer_1;" " }" " : row" " {" " : boxed_column" " {" " label = \"Sort By\";" " : rrw" " {" " : radio_button { key = \"blk\"; label = \"Block Name\"; }" " : radio_button { key = \"qty\"; label = \"Quantity\"; }" " }" " spacer;" " }" " : boxed_column" " {" " label = \"Sort Order\";" " : rrw" " {" " : radio_button { key = \"asc\"; label = \"Ascending\"; }" " : radio_button { key = \"des\"; label = \"Descending\"; }" " }" " spacer;" " }" " }" " spacer_1; ok_cancel;" "}" "" "//----------------------------------------------------------------------//" "// End of File //" "//----------------------------------------------------------------------//" ) (write-line itm des) ) (setq des (close des)) (while (not (findfile dcl))) ;; for slow HDDs dcl ) ) ) ;;----------------------------------------------------------------------;; (defun count:writecsv ( lst csv / des sep ) (if (setq des (open csv "w")) (progn (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (","))) (foreach row lst (write-line (count:lst->csv row sep) des)) (close des) t ) ) ) ;;----------------------------------------------------------------------;; (defun count:lst->csv ( lst sep ) (if (cdr lst) (strcat (count:csv-addquotes (car lst) sep) sep (count:lst->csv (cdr lst) sep)) (count:csv-addquotes (car lst) sep) ) ) ;;----------------------------------------------------------------------;; (defun count:csv-addquotes ( str sep / pos ) (cond ( (wcmatch str (strcat "*[`" sep "\"]*")) (setq pos 0) (while (setq pos (vl-string-position 34 str pos)) (setq str (vl-string-subst "\"\"" "\"" str pos) pos (+ pos 2) ) ) (strcat "\"" str "\"") ) ( str ) ) ) ;;----------------------------------------------------------------------;; (defun count:writetxt ( lst txt / des ) (if (setq des (open txt "w")) (progn (foreach itm lst (write-line (count:lst->str itm "\t") des)) (close des) t ) ) ) ;;----------------------------------------------------------------------;; (defun count:lst->str ( lst del ) (if (cdr lst) (strcat (car lst) del (count:lst->str (cdr lst) del)) (car lst) ) ) ;;----------------------------------------------------------------------;; (defun count:padbetween ( s1 s2 ch ln ) ( (lambda ( a b c ) (repeat (- ln (length b) (length c)) (setq c (cons a c))) (vl-list->string (append b c)) ) (ascii ch) (vl-string->list s1) (vl-string->list s2) ) ) ;;----------------------------------------------------------------------;; (defun count:setblocktablerecord ( obj row col blk ) (eval (list 'defun 'count:setblocktablerecord '( obj row col blk ) (cons (if (vlax-method-applicable-p obj 'setblocktablerecordid32) 'vla-setblocktablerecordid32 'vla-setblocktablerecordid ) (list 'obj 'row 'col (list 'count:objectid (list 'vla-item (vla-get-blocks (count:acdoc)) 'blk)) ':vlax-true ) ) ) ) (count:setblocktablerecord obj row col blk) ) ;;----------------------------------------------------------------------;; (defun count:objectid ( obj ) (eval (list 'defun 'count:objectid '( obj ) (cond ( (not (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*")) '(vla-get-objectid obj) ) ( (= 'subr (type vla-get-objectid32)) '(vla-get-objectid32 obj) ) ( (list 'vla-getobjectidstring (vla-get-utility (count:acdoc)) 'obj ':vlax-false)) ) ) ) (count:objectid obj) ) ;;----------------------------------------------------------------------;; (defun count:assoc++ ( key lst / itm ) (if (setq itm (assoc key lst)) (subst (cons key (1+ (cdr itm))) itm lst) (cons (cons key 1) lst) ) ) ;;----------------------------------------------------------------------;; (defun count:effectivename ( ent / blk rep ) (if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**") (if (and (setq rep (cdadr (assoc -3 (entget (cdr (assoc 330 (entget (tblobjname "block" blk) ) ) ) '("AcDbBlockRepBTag") ) ) ) ) (setq rep (handent (cdr (assoc 1005 rep)))) ) (setq blk (cdr (assoc 2 (entget rep)))) ) ) blk ) ;;----------------------------------------------------------------------;; (defun count:startundo ( doc ) (count:endundo doc) (vla-startundomark doc) ) ;;----------------------------------------------------------------------;; (defun count:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;;----------------------------------------------------------------------;; (defun count:acdoc nil (eval (list 'defun 'count:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (count:acdoc) ) ;;----------------------------------------------------------------------;; ;; End of File ;; ;;----------------------------------------------------------------------;;
Hi Patrick,
The Visual Lisp customization forum will be more suitable to post this query.
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/bd-p/130
Also, please clarify on what the expected output is when you mean "also count footages"
Attaching a sample drawing and explaining the expected output will surely help in understanding your query.
Balaji
