AutoCAD 2013/2014/2015
Member
construccion777
Message 1 of 6 (152 Views)
Link two points
152 Views, 5 Replies
07-23-2012 07:59 PM
There are to points and between them a lot of obtructions therefore there is not possible to link using only ome line. Is there a command to link ?
grimline
Message 2 of 6 (147 Views)
Re: Link two points
07-23-2012 09:26 PM in reply to: construccion777
PLINE command
Autodesk AutoCAD Map 3D 2015
Windows 7 Professional
Service Pack 1
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
Member
construccion777
Message 3 of 6 (132 Views)
Re: Link two points
07-24-2012 07:42 AM in reply to: construccion777
Yes but you have to define the path . I am looking for an automatic method . This is very usefull to design circuits.
dbroad
Message 4 of 6 (120 Views)
Re: Link two points
07-24-2012 08:30 AM in reply to: construccion777
You'd have to investigate available verticals or third party apps..  Automatic routing is not available in Autocad base.
JDMather
Message 5 of 6 (111 Views)
Re: Link two points
07-24-2012 11:26 AM in reply to: construccion777
Are you familiar with parametric geometry constraints?
Post an example file here.
Might be as simple as coincident constraint.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
construccion777
Message 6 of 6 (103 Views)
Re: Link two points
07-24-2012 12:30 PM in reply to: construccion777
Thank you I will check the example
