AutoCAD 2013/2014/2015
Distinguished Contributor
jackshield
Message 1 of 10 (655 Views)
LINETYPE with two colors?
655 Views, 9 Replies
08-06-2013 08:22 AM
I need to represent some lines, in model space, that alternate in color, yellow/red, that are "scalable" with respect to different sscale viewports in paperspace.
my initial idea was to use two lines, each in which the dash and space between were the same distance, then just offset the yellow/red lines enough for each to fill the others gaps.
but, wondering if it was possible to represent that in a single linetype?
dbroad
Message 2 of 10 (637 Views)
Re: LINETYPE with two colors?
08-06-2013 09:10 AM in reply to: jackshield
No.  You might  be able to use an associative array to do what you want but colors are set at the object level (except for mtext)
vladimir.michl
Message 3 of 10 (618 Views)
08-06-2013 10:32 AM in reply to: jackshield
You can do this with multilines - see
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=1818
Vladimir Michl, www.cadstudio.cz
jackshield
Message 4 of 10 (600 Views)
08-06-2013 11:43 AM in reply to: vladimir.michl
DING DING DING ... WE HAVE A WINNER!
This is perfect!
jackshield
Message 5 of 10 (593 Views)
08-06-2013 12:01 PM in reply to: jackshield
AND THE PARTY WAS SHORT LIVED!
being able to assign width was another factor, no option for that with mline?
vladimir.michl
Message 6 of 10 (585 Views)
08-06-2013 12:10 PM in reply to: jackshield
Do you mean linewidth? A standard linewidth property applies also to MLines - see the Properties palette (Ctrl+1) and switch LWidth display On.
Vůadimir Michl, www.cadstudio.cz  www.cadforum.cz
jackshield
Message 7 of 10 (579 Views)
08-06-2013 12:19 PM in reply to: vladimir.michl
not seeing that option, but that would be great if i can find it ...
vladimir.michl
Message 8 of 10 (574 Views)
08-06-2013 12:25 PM in reply to: jackshield
Sorry, it is called lineweight (not using the English version) in the Properties. The display switch can be toggled with the LWDISPLAY variable.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
jackshield
Message 9 of 10 (567 Views)
08-06-2013 12:38 PM in reply to: vladimir.michl
yea, thats line weight, it applies to plotted values.
i was referring to line width, as with polylines, you can assign width to line.
i am representing some painted lines for aisles, 1:1 in model space.
for now, i am using a polyline, solid yellow, with a copy that is a dashed red.
created linetype for the red to be 10" spacing.
each bylayer, i move the red to the front, and above other objects.
this gives me the dashed line without too much trouble.
although i will use the mline option in the future, where a line width is not required.
RafaelMoreno
Message 10 of 10 (203 Views)
04-17-2014 12:41 PM in reply to: jackshield
Hi guys:
It was so nice to find this CAD forum that you are talking about. Much appreciated. Anyway, I have a problem setting colors as soon as I have mlines in the drawings whose styles become are not longer available. Any ideas?
Rafael
