Hi All,
I'm having some issues with my ltscale. Normally LTSCALE is set to 60 and PS and MS = 0.
I'm not sure what I've done or clicked but not of the line types are showing correctly now across all of my drawings.
If anyone has any advice I'd be very grateful 🙂
Hello
Welcome to the Autodesk/AutoCAD Forums !
Please which version of ACAD exactly ?
So on many DWGs, now you have problem only in Model Space and/or you have also problems in Layouts !?
PSLTSCALE = 1 for each layout ?
Patrice BRAUD
If they plot/print correctly, but just don't show correctly on-screen, and if "not correctly" means that non-continuous linetypes show as continuous [rather than of the correct pattern but wrong scale], you may just need a higher resolution setting under the VIEWRES command.
