AutoCAD Forum
Lines connecting text objects-how to get rid of
3 REPLIES 3
floresc
974 Views, 3 Replies
I just got AutocadLL15 and when i open old drawings i got lines connecting texts and also among copied objects, does anybody know how to get rid of  these annoyng lines? Thanks.
3 REPLIES 3
anogramatic
in reply to: floresc
Try the PURGE command.  ALternatively, if the lines are on a set layer, select one of the lines, freeze off all other layers, then select all and delete.
GrantsPirate
Based on posts from yesterday, start by turning hardware acceleration off.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
floresc
in reply to: GrantsPirate
Really easy. Problem solved. Thanks.
”Boost
