I just got AutocadLL15 and when i open old drawings i got lines connecting texts and also among copied objects, does anybody know how to get rid of these annoyng lines? Thanks.
Solved by GrantsPirate. Go to Solution.
Try the PURGE command. ALternatively, if the lines are on a set layer, select one of the lines, freeze off all other layers, then select all and delete.
Based on posts from yesterday, start by turning hardware acceleration off.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
