AutoCAD Forum
Lines are only visible when selected AutoCAD 2015
4 REPLIES 4
944 Views, 4 Replies
Hello, I am new in AutoCAD 2015, I had used older versions but I never had that problem, when I draw a line it doesn't appear like if it didn't draw it, they only appear if I select them with selection tool. Probably is an issue easy to solve but I am unable to do it.
4 REPLIES 4
nestly2
Is it possible that the lines are the same color as the background?
Can you post a sample drawing containing some lines?
braudpat
Hello
Welcome to the Autodesk/AutoCAD Forums !
+1 with Nestly2
1) But have you tried with hardware graphic acceleration OFF ?
2) And/Or with LINESMOOTHING = 0
3) Have you installed the SP 1 and/or the SP 2 on your 2015 ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
in reply to: braudpat
Thanks, it was the hardware graphic acceleration
AJHobbs
Hello
I am having a similar problem.    I have looked at turning the hardware graphic acceleration OFF however can;t find advice on how to do this.   Could this be because I am working on a macbook?
”Boost
