AutoCAD 2013/2014/2015
Valued Contributor
simon_toaldo
Message 1 of 3 (236 Views)
line weight
236 Views, 2 Replies
10-22-2012 05:31 PM
In a sketch block how do you change the line weight...i tried through Block Editor but cannot change...lineweight is currently 0.25mm but i want to change to .70mm....i am missing something here..
ST
*Expert Elite*
Alfred.NESWADBA
Message 2 of 3 (219 Views)
Re: line weight
10-23-2012 02:01 AM in reply to: simon_toaldo
Why not? If you start the blockeditor for this block, then select the geomtry you want to modify and set it to a layer with anohter lineweight (or you modify it's lineweight .... not the best way :smileywink: ) ... why does that not work?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
JDMather
Message 3 of 3 (210 Views)
Re: line weight
10-23-2012 04:22 AM in reply to: simon_toaldo
Attach the file here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Post to the Community
New Post
Need installation help?
