AutoCAD 2013/2014/2015
1 Kudo
Post 1 of 6
Accepted Solution
Line type scale
5060 Views, 5 Replies
06-04-2012 11:17 PM
I have a problem with line type scale for hidden line it appears different line type scale in another drawing, al though the setting for line type scale & Global scale factor is same for both the drawings. Is there any other setting for the line type.
Please Help.
Awes
it may be possible, that one drawing is started with imperial settings and the other drawing is based on metric units.
Therefor AutoCAD loads the linetype from ACAD.LIN or in the second case from ACADISO.LIN ==> and within these two linetype-definition-files the distances are different.
To get it solved you can:
  • a) select all entities with that linetype
  • b) copy them to a temporary new drawing
  • c) delete them in the current drawing
  • d) run command _PURGE to clean this linetype
  • e) load the correct linetype either from the LIN-file (the one you need) or by copy one element from a drawing where the scaling is as you need
  • f) then copy the objects from your temporary drawing to the active drawing.
The easier way, if you don't have any special settings, any special layouts:
  • a) copy the drawing where the linetype scale is correct to a new filename
  • b) erase everything in it (but don't purge the definitions)
  • c) copy all your objects from the "defect" dwg to this new empty one
Just to make sure, there are three global settings to compare
  • PSLTSCALE
  • MSLTSCALE
  • LTSCALE
and last but not least you could have assigned every object a different linetype-scale-factor
HTH, - alfred -
Alfred is right in saying that the CAD file is using a different LIN file (because one drawing started with a metric template, and the other with an imperial template).
However, Alfred's method to solve the issue is the long-way-around, (sorry, Alfred) and there is a much EASIER way to fix your lines.
1. Enter the command MEASUREMENT (note: NOT "Measure") and set the value to either 0 (zero - to load imperial linetypes) or a value of 1 (one - to load metric linetypes)
2. Then, enter the command LINETYPE, click the LOAD button, and from the LIN file being displayed, select all the linetypes shown in the window and click OK, and when the "Relaod Linetypes" dialog appears, select "Reload ALL Selected Linetypes" and click OK twice to get back to the command line
3. Back in your drawing, enter the command REGENALL, and set the LTSCALE accordingly.
*Expert Elite*
1,219 Kudos
Post 2 of 6
Re: Line type scale
06-04-2012 11:33 PM in reply to: abm2k
  • PSLTSCALE
  • MSLTSCALE
  • LTSCALE
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Pro
80 Kudos
Post 3 of 6
Re: Line type scale
06-05-2012 05:26 AM in reply to: Alfred.NESWADBA
*Expert Elite*
1,219 Kudos
Post 4 of 6
Re: Line type scale
06-05-2012 05:32 AM in reply to: murray-clack
you are right, that is a faster way than mine ... without one exception: I'm sure that my way works to get the same linetype from another drawing.
Your way assumes that the linetype in the "source-drawing" (to which it's compared) comes from an unmodified ACAD.LIN or ACADISO.LIN
Anyway, under normal circumstances and with AutoCAD-defined linetype-names your way is really faster :smileywink:
BTW: if you select the correct linetype-file you even won't have toset MEASUREMENT or MEASUREINIT before (one less step ==> more faster then) :smileyhappy:
- alfred -
Alfred NESWADBA
Valued Mentor
14 Kudos
Post 5 of 6
Re: Line type scale
06-05-2012 10:13 AM in reply to: abm2k
Unzip the two attached scripts to your desktop. Drag and drop into the Autocad drawing window as needed.
1 Kudo
Post 6 of 6
Re: Line type scale
06-06-2012 01:01 AM in reply to: murray-clack
Thanks Murray
Thanks for your solution this faster & easiest way
Thanks Again
Awes
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
