AutoCAD 2013/2014/2015
Active Contributor
0 Kudos
Post 1 of 8
line thickness
6835 Views, 7 Replies
05-13-2013 09:00 AM
How is it possible to view the line thickness that you have set at the drawing surface? before you polot. I mean drawing and working  with the actual line thickness that you set for the layer? and i do not mean using pline
thank you
*Expert Elite*
2,120 Kudos
Post 2 of 8
Re: line thickness
05-13-2013 09:08 AM in reply to: zzzz0r
Try Plot>Preview.
Is that what you are after?
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
*Expert Elite*
312 Kudos
Post 3 of 8
Re: line thickness
05-13-2013 11:50 AM in reply to: zzzz0r
The Show/Hide Lineweight toggle below?
*Expert Elite*
473 Kudos
Post 4 of 8
Re: line thickness
05-14-2013 04:06 AM in reply to: zzzz0r
I'm guessing you mean lineweight, not thickness. Thickness is the "height" of an object in the Z axis.
Lineweight is the perceived "width" of an object, visible only when the lineweight toggle is turned on.
Then again, you can apply lineweights at plot time only using a plot style table in your pagesetup, and not use the AutoCAD lineweight feature at all.
Here are two lines, one with a thicker lineweight applied and the other set at 0.0
The LWT toggle is on.
*Expert Elite*
127 Kudos
Post 5 of 8
Re: line thickness
05-14-2013 04:17 AM in reply to: zzzz0r
In addition to what the others have mentioned, if you also want to see lineweights in your plots you will want to check the Scale Lineweights box in the basic (left) portion of the Plot dialog, and the Plot Object Lineweights in the expanded (right) portion of the same dialog.
All of the suggestions given so far should help you both in your model and in plots.
Dave.
Dave Hein, P.E.
Valued Contributor
1 Kudo
Post 6 of 8
Re: line thickness
08-13-2014 04:11 AM in reply to: JGerth
where is the lineweight toggle in AutoCAD 2015?
Regards!
*Expert Elite*
461 Kudos
Post 7 of 8
Re: line thickness
08-13-2014 04:48 AM in reply to: mark.martin.se
Click on the customization icon on lower right to enable the Lineweight toggle.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Valued Contributor
1 Kudo
Post 8 of 8
Re: line thickness
08-13-2014 05:26 AM in reply to: Jay_B
OK,...thank you!
Best regards!
Post to the Community
New Post
