Ok, so I just started using CAD 2015 2 weeks ago and ever since it has been installed i have had this issue. When I use a corner to extend off of and draw a line at 15" it will place the line randomly instead of 15" perpendicular to said node. I have tried reloading other "Profiles" but it has had no affect on my current problem.
Solved by nestly2. Go to Solution.
Edgemode is set to "0".
I just tried changing this varilble and i still am having the same issue. It will recognize the corner OSNAP but when I try to project off of said SNAP it does whatever it wishes.
From HELP:
EDGEMODE controls how the TRIM and EXTEND commands determine cutting and boundary edges:
0 = Uses the selected edge without any extensions
1 = Extends or trims the selected object to an imaginary extension of the cutting or boundary edge.
Well that solves another issue with this setup that I have been having but not the one im trying to solve.
Any ideas with the other issue? 😕
I don't think EDGEMODE is relevant, but may have come to mind simply because of the word "extension" in the Subject line. But I confess that it's not clear to me what you're trying to do, and the images don't clarify it for me. Something can't be perpendicular to a node [at least, not in AutoCAD's meaning of the word]. Are Polar and/or Object-Snap Tracking involved? Is Ortho mode on? A more detailed description of the steps you're taking, and the results, would be helpful to me.
In this image you can see the line highlighted in red, this is what I'm talking about. Currently to place lines off of corners of walls I have to draw that line. What I would like to do is be able to use that snap to project from (I guess that would be the correct term?) and not have to erase an unecessary line everytime I try to pull off of an OSNAP. It doens't have to be a corner I just used it for these visusals all OSNAPS give me this problem.
In your example, it appears the Extension Osnap is activated and tracking 270 degrees. Are you staying that if you type "15" while Extension > 270 is displayed the line goes "anywhere"? Do you have the Tracking vector turned on, and can you see it?
Here is a picture of typing in "15" 4 times, each time the "15" producted a different location. In the photo the arrow points to the point of where the line would start. The end point is just where I terminated the line, angles are irrelevant. This would be off the same corner that I have used throughout this problem.
Is the Endpoint OSnap on (or activated)?
If yes, do you see the AutoTrack marker after acquiring the Endpoint?
If yes, do you see the Tracking Vector when your cursor is near your Polar tracking angles (30 degrees for you, 45 degrees in animation below)
If yes, is the Osnap and angle displayed at the cursor when you're hitting one of your Polar tracking angle?
If yes, are you typing in your distance while the tracking vector is still displayed?
Nice animation, and the answer is yes to all of those.
The only difference is that in every instance of those lines I drew I was at a Polar tracking angle of 270 (with increments of 30 degrees).
After entering 15 and a polar tracking angle of 270 this is the result that it produced. Again with a seemingly random point 5'-5&1/4" down by 4'-6&3/8" left.
Hmmm.
So the Tracking vector is displayed, and the tooltip says "Endpoint > 270" and when you type "15 + <enter>" the line is not directly below the endpoint you were tracking from?
Try turning off Perp Osnap (and NEArest, and (TANgent), and/or manually assign Endpoint Osnap. Running PERP osnap is known to cause errant results in certain situations.
I didn't know that it caused issues, it's off currently and yet I still have a line that isn't correct in placement. However it is 1/16" off of 15"
Just to be clear
After 5 tests, I'm almost starting to think that it places my line realitive to my cursor.
