Hi All,
I would like to share plugin LevelSet v2.0 which measures the perpendicular distance from a base point to features, for example slab. LevelSet resembles the AutoCAD Ordinate dimension but the main differences are:
LevelSet properties window has similar entries as AutoCAD dimension style manager:
Example of possible LevelSet settings:
For users using older LevelSet version 1.7
Firstly thank you all who sent me ideas for improvement or reported bugs. Without your input I wouldn’t do any further changes (I created v1.4 for my needs and it worked well, but I would like to create the versatile tool for as many users as possible).
What is new in version 2.0
Richard
Is app not loaded or you have some problem with crashing?
It should work with AutoCAD 2014 as we run this version. Make sure you netload dll file in 2013 folder.
The app is working correctly.
first time it can not be loaded but I don't know the reason.
now I am working with this app and it makes me my job easier.
Thanks for your sharing this great app with us.
Any problem or question please feel free to contact me on email provided within the app help
Richard
This is EXACTLY what I needed. Thank you SO MUCH for sharing this!!! I can confirm that it works on AutoCAD Mechanical 2014.
Cheers!!!
Nino
When you upgrade to ACAD 2015 or newer in the future, download app version from autodesk app store. I don't submit any update here any more only on app store.
https://apps.autodesk.com/ACD/en/Detail/HelpDoc?appId=8340451895184896684&appLang=en&os=Win32_64
Cheers,
Richard
Hi everyone this is my first time posting, I developed this block some time ago and i hope that some of you may find it useful. the block is in mm but the readout is in m. As it utilises a visibility state for each scale, do not make the block or its dimensions annotative.
I hope this is of use to you.
Best regards Finn
