i attached one drawing as a xref.in this drawing when i see layout than it showing all layer but all are white color
model i can see all color as per layer but in layout it not showing it showing only white .when print than ok but view only white.how i can changed this setting suggest me
Solved by 3wood. Go to Solution.
Solved by imadHabash. Go to Solution.
keep xref or block same file only i want to know layout view why it is not showing the color as it showing in model space
https://www.dropbox.com/s/8ho79pvgpy362q3/ACAD-P03-SDG-S-FIF-OBH-3024207-00.dwg?dl=0
Command PAGESETUP ->Modify button ->Clear"Display plot styles" option as shown below:
