AutoCAD Forum
Layout Tab Missing
14 REPLIES 14
Message 1 of 15
DonScribner
3666 Views, 14 Replies
Layout Tab Missing
I loaded 2015 right out of the box.  No customizations (yet).  Nothing non-standard running.  But just like the other 7 installaions I've done inside the company, the Layout Tab (containing the Create View panel, Modify View panel among others) is missing.  And when I say missing, I mean not available no matter Workspace I try.  This is completely unacceptable.  Any ideas as to how to get this back?
Don
If you'd like to email me at dscribner@wascoproducts.com that would be fine.
14 REPLIES 14
Message 2 of 15
pendean
in reply to: DonScribner
Layout Tab, in the Ribbon? What version had that? Looking at 2011, 2012, 2013, 2014 and 2015 here OOTB and I don't see a Layout Tab in either of them.
Message 3 of 15
rkmcswain
You mean this, right?
That has been there since at least 2013 IIRC. I know because it's one of the first things I disable on a new install.  I don't know why it would not be there. Have you checked the CUI to see if it's in there but just not enabled to appear when a layout is selected? Did you upgrade an existing install and if so, did you let it do a "migrate settings"?
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 15
pendean
in reply to: rkmcswain
Ah! I missed that altogether, the LAYOUT tab appears on the far right in the tab only when AutoCAD is maximized here (while in a layout tab). I wonder if the OP has the same problem.
Message 5 of 15
greg_battin
Message 6 of 15
DonScribner
in reply to: greg_battin
Message 7 of 15
DonScribner
I'll try this again.
See he attached for the parts that I'm missing.  The "Layout" and "Layout Views" panels are there but everything else is missing.  I used them in 2013 so they should have migrated at very least.
Message 8 of 15
DonScribner
Message 9 of 15
greg_battin
I'll be happy to help some on this but - but can yo0u post a screen shot of the 2015 layout tab that is missing the panels please?
Below is a snap shot of the layout tabs for 2013, 2014 & 2015
Message 10 of 15
DonScribner
Greg,
Yes, that's what they are supposed to look like.  (I did attach a PNG file)
Everything to the right of "Layout Viewports" is gone.
Message 11 of 15
greg_battin
Sorry - I missed your screen shot.
Try this:
With a layout tab (Paper space) active,
Click on the Layout tab in the ribbon and then right click anywhere on the ribbon.
You will see the below options in the right-click menu.
Click on "Show Panels" and then make sure that the panels listed have check marks next to them  (shown below)
If this doesn't work and you don't mind resetting the settings to their out-of-the-box state so that you can start from scratch, you don't have to repair or re-install, you can use the "Reset to Default" option from the start menu (shown below).
  • Click Start menu
  • All Programs
  • Autodesk
  • "AutoCAD 2015 - English"
  • click "Reset Settings to Default"
I hope this helps
~Greg
Message 12 of 15
DonScribner
Nice  .  .  .  .  Now the entire Panel is MISSING!  What next???
Message 13 of 15
greg_battin
Here's what I can tell from the screen shot that you just posted:
This is what I think is shown above
Do the following:
~Greg
Message 14 of 15
DonScribner
Greg,
Thanks for your help. I'm good.
DOn
Message 15 of 15
greg_battin
Cool - I'm glad it helped
”Boost
