Hallow my friends, I have problems with Layout Annotate.
there are linears on the 1 and 3 views but, linears are not on the 2 and 4 views. there is no problem on this picture. I have a second picture it's simply drawing
as you can see there are lines inside red circles and in front of arrows. I want to hide this lines in the views. I do not know what can I do. Help me please
Solved by GrantsPirate. Go to Solution.
yes I know that they are dimensions lines and I wonder how can I manage that dimensions line should be only on the view where I point and not to be shown on the other views. and how can I manage to do like this
there are shown dimensions lines on 1 and 3 views and not on 3 and 4. I want to do like this
Create different layers for the dimensions and freeze / thaw accordingly.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Thank you for your answer. I have individual layer for Dimension lines but when I try to freeze this dimension lines on the first view
you can see that each of lines hide.
what can I do???
You need 3 layers (at a minimum) for dimensions for your example. Place the dims you want to show in the top view on their own layer, repeat for side and front views. Freeze and thaw with the VPfreeze column in the layer manager so the freeze function only works for the current viewport. Rinse and repeat for other viewports.
GrantsPirate
Thank you very much
I have another question. there are green broken lines inside model in front of red arrows.How can I do like this.
Hayyyy
