AutoCAD Forum
Layers and underlays
8 REPLIES 8
Message 1 of 9
406 Views, 8 Replies
Hi all
I can't figure out if underlays are part of a layer/connected to a specific layer or another thing altogether.
Please help?
8 REPLIES 8
Message 2 of 9
rkmcswain
Similar to a regular external reference (xref), but with differences.
See this:
http://docs.autodesk.com/ACD/2014/ENU/files/GUID-09D63C05-6647-4086-B7E3-86A019E4F93D.htm
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 9
in reply to: rkmcswain
Thanks, I have read that but it doesn't answer my question.
Message 4 of 9
What I want to know is can I treat the underlay like any other drawing and move it around between layers and the like?
I by mistake drew on the same layer as my underlay (it looks like it is in the layer) and now I would like to move it to it's own layer. At first I thought the underlay should be a separate thing, like a base layer.
Message 5 of 9
sthompson1021
Yes, you can move the underlay to a different layer. Just select the underlay and use the properties pallet to change the layer.
Message 6 of 9
in reply to: sthompson1021
Thanks, experiemtning helps. I see it now.
Message 7 of 9
rkmcswain
Yes, just like any other entity.
I can't think of anything in AutoCAD that is "connected to a specific layer".
Message 8 of 9
By connected i guess I mean in the layer as opposed to anindependant entity. Actually I had placed everything in layer '0' and could not edit it which is why I thought somehow that what I had done (add an underlay) somehow changed things. Then I read why and discovered it's a 'newbie' mistake. lol
I'm clear on it all now.
Message 9 of 9
jggerth
Dimension NODe entities for associative dims on Defpoints?
but as far as 'user usable' things, you're right.
”Boost
