AutoCAD Forum
Layer State File (.las) syntax Question
1 REPLY 1
dnl999
468 Views, 1 Reply
I am trying to understand the Layer State File Syntax in the .las file and I found the attached helpful information on the net.
As you can see the code 90 represents the layer state (e.g. on/off/frozen/locked/no plot) and the number ranges from 0 to 15.
Everything was fine until I started to see some numbers higher than 15 (e.g. 24, 35, 43, etc) when I exported a layer state from one dwg file.
Is there some additional documentation which explains how to retrieve the basic layer state (i.e. on/off, freeze/thaw, locked, no plot) information from these number higher than 15 ?  I am thinking that it has to do with the bit pattern of the number.  Certainly, Autodesk staff must know so please help !
Thanks in advance for your reply.
Andrew,
1 REPLY 1
dnl999
in reply to: dnl999
 The 90 code numbers consistently being returned and over 15 are mainly four:  16,24,35 and 43
If this is not documented anywhere can some one (hopefully Autodesk ?) tell me what each of these number represent in terms of on/off, freeze/thaw, locked, no plot ???...  Thanks.
”Boost
