Good moring,
I have lost my Layer Property Manager. I searched the forums and found the ALT+SPACEBAR and then M solution, but that is not working for me. I am working in AutoCAD 2015 (well I was I've had to go back to 14 because I use the Layer Property Manager all of the time) on dual moniters. I thought I must have moved it way off screen, but as I've said the solutions in previous posts are not working.
I usually try to rememeber to dock my windows/boxes (what are they called?) at the end of a work session. I honestly can't remember if I did that the last time I worked with 2015.
Is there a command to dock all windows/boxes?
Please help.
Thank you,
Solved by nestly2. Go to Solution.
You can bring it back through the CUI. The demo below is for a missing Command Line, but it works basically the same for any Palette. As soon as you "Apply" the changes, you should see the changes reflected in the workspace
